find replacement window screens
Any suggestions on where to find replacement window screens for a 1997 Chinook Premier? Dog scratched through them on our first trip, as I feared.
Re: find replacement window screens
I just purchased a rebuild kit at Lowes (or maybe Home Depot) and installed the new screen myself. This assumes one still has the aluminum frame.
If the frame still good, can't you just bring it to a window shop and have it re-screened?
I'm in the same boat, but for my Concourse, which has some really weird angles. And the whole screen is missing, including the frame, in my case. No dog.
Anyone have suggestions?
2001 Premier aka "Anookie"
Dallas, TX area
Dallas, TX area
HappyCamper
Does anyone have a good method to lubricate the 2000 Concourse window shade string guides? I plan to to "grease" the strings with silicone lubricant to make them easier to slide up and down. Better ideas?
Never thought of that, but my opinion is that you want to use something that don't attract dirt and dust, so nothing sticky when dried. Definitely not grease (solid) lub... what everyone think?
McLube SailKote is a high quality dry lubricant that will not attract dust. It goes on wet but dries in seconds.
It is, in my opinion, the very best dry lubricant you can find.
The only con and this is a big con, is that it is very expensive and hard to find.
I removed those original blinds because they didn't really work for me, but.... a couple considerations before lubricating the strings:
1) If you drive with the blinds down, the lower frames bang on the windows (could perhaps be mitigated).
2) If you silicone lubricate the strings, the blinds may not stay up when you want them to? Especially when driving.
Maybe neither of those things affect you.
HappyCamper
Thanks Larry and Blu. I will try to fine the McLube SailKote. Sounds like it might do the trick. Jim
