Beep when starting engine if coach batteries are switched ON
Posted: October 31st, 2017, 3:05 pm
by Chinookers
Anyone know why I get a beep (or two beeps, or even three) when I start the engine when the coach battery switch is turned ON?
Does not happen all the time, but fairly often.
Didn't used to do it
NO beep when starting if the coach battery switch is OFF.
Thanks in advance
Re: Beep when starting engine if coach batteries are switche
Posted: October 31st, 2017, 4:51 pm
by Colorider
Is it your LP gas detector? Near the sink?
Posted: October 31st, 2017, 5:51 pm
by Chinookers
No it's not from the gas sensor. It beeps right up front - sounds as though it's from the dashboard
Posted: November 1st, 2017, 1:47 pm
Chinookers wrote:Anyone know why I get a beep (or two beeps, or even three) when I start the engine when the coach battery switch is turned ON?
Thanks in advance
Is it the same beep as when the LVD is about to go off (where you have to react or plug in within 30 seconds)? Maybe the coach batteries are inadvertently tied to the starter battery and getting a dip when you start. That could be a Sure Power switch problem, as well as perhaps a weak starting battery.
Posted: November 6th, 2017, 7:45 am
by Kirah
I now get a few alarm peeps when I start mine, but it didn't start doing that until my house batteries were basically shot. In the past, when I've put in new batteries, that alarm has disappeared until I managed to ruin the new batteries (There's been a learning curve for me...) and then it comes back. It very distinctly sounds like it's coming from above my head, though, not from the dash, so it may not be the same thing.
