Absorption refrigerator
Posted: February 23rd, 2021, 1:46 pm
Hi. I just purchased a 1976 dodge chinook 18 plus 2. I am checking the absorption refrigerator right now.
It is Dometic Model RM 66E or RM 66.
It is missing the bottom left has lighting push in knob. So I was able to light it manually from the outside of the rig on the backside of the refrigerator. The flame is nice and wide and blue. I’m letting it sit overnight to see if the refrigerator actually cools down. If it doesn’t then I guess it means that the absorption system has issues- rust, ammonia leaked or crystallized or ....?
If the system does work then next is to try it on shore power. Then on 12volt power.
Do the both electrical systems (110v and 12v) both use the same mechanism to heat up the ammonia?
Is it possible to run this refrigerator completely on 12v?
Can I use a new car battery as the house battery for the RV 12 volt system or must I change it to a few cycle battery?
If this refrigerator works for 110v/12v/LP......is the u it itself inefficient because it is form 1976 or no ? A burning LP flame is cheap as well as a 12v heating unit is a low draw in the battery?
Thanks,
Charlie
Thanks,
Charlie
