Dometic Royale Fridge
Dadams6612
Post by Dadams6612 »
Anyone know of a good replacement, one that still runs off LP, DC & AC?
Re: Dometic Royale Fridge
What's wrong with your existing fridge? It is a lot of work to replace it, from the various threads I read here.
Dadams6612
My guess is that has sat too long , now that I'm having trouble with my outlets it will not go to AC, the fridge qont get cold on propane. And now wont kick over to propane. Too many issues at one time I guess
I was having problem with mine not working on propone or kicking unto propane until I clean out the pilot light area. The tube under chimney had a lot of debris in it, worked perfect right away once done. There are good youtube videos on how to do it.
I would concentrate on the 110 AC for now. It is expected that it won't kick over to AC if the AC has issue. I think some of us have a spare control board if you ask around, but I won't bother with it until you get your AC power up and working.
The Dinosaur circuit board upgrade could prove helpful as well. Many threads on that. Simple fix and has saved a couple of refers for me.
