Page 4 of 5
Re: New member
Posted: August 18th, 2020, 12:15 pm
Scott wrote: August 18th, 2020, 8:56 am
Baja Bilo wrote: August 18th, 2020, 6:18 ambut I'm sure you
could find something wrong with any conversion.
Then why convert?
Generally speaking, people do this despite the disadvantage because of the expected pay-off out weights the issue. It is like we still takes some medication even if there is a long list of possible complications, it is not prison because there is some benefit.
Re: New member
Posted: August 18th, 2020, 9:46 pm
by Baja Bilo
Then why convert?
Because the stock ride is shit. They are way under sprung,
and if I want to head south in the winter the added 4x4
is a benefit driving on snow packed roads.
Re: New member
Posted: August 18th, 2020, 10:22 pm
by dougm
You cant dispute the advantages of having four wheel drive. But somehow i think youre fooling yourself if you think theres going to be some dramatic improvement in ride quality by switching to a straight axle with leaf springs. Its a 5 ton truck before its ever loaded and its always going to ride like a 5 ton truck. You strip out the independent front suspension in exchange for a solid axle, by default you just made the ride quality harsher by making it impossible for each side of the truck to react to a bump independently of each other. But as long as you have yourself convinced that its going to make it ride like your family sedan thats all that matters.
Re: New member
Posted: August 19th, 2020, 9:03 am
by Baja Bilo
dougm wrote: August 18th, 2020, 10:22 pm
Never said it was going to ride like a Cadillac I know it's a one ton
van chassis. The RV manufactures purchase the cut away chassis
and they never do anything to the rear springs to compensate for
the weight of the rig. I used to travel the country installing carpet
in hotels. I had a E350 extended 7.3 Powerstroke van as my work rig.
I had it converted to a 4x4 because on snow packed roads a van sucks.
It sure helped driving on snow covered roads in winter. I also know that
converting it to a 4x4 isn't going to make it a rock crawler. The reason
I want it to be a 4x4 is so I can travel year round in any type of driving
conditions. If you're happy with what ever rig you have that's all that
matters. It is what it is.
Re: New member
Posted: August 19th, 2020, 9:17 am
by dougm
Re: New member
Posted: August 20th, 2020, 7:35 am
by markatherton
I am very happy with my Quigley conversion; I found that achieving the "best ride" was by weighing the front and rear of the vehicle and then adjusting the air pressure as per the tire manufacturers specifications; I was shocked how low the correct tire pressure was. (see Blue's discussion in this forum); Once I had the correct tire inflation the ride was much improved.
Re: New member
Posted: August 20th, 2020, 9:01 am
by Baja Bilo
markatherton wrote: August 20th, 2020, 7:35 am
Nice looking rig
Re: New member
Posted: November 26th, 2021, 10:35 am
by Warthogg
Baja Bilo.....
Is that your rig at UJoint?
If so, it looks awesome!
Re: New member
Posted: November 29th, 2021, 7:30 pm
by Baja Bilo
Warthogg wrote: November 26th, 2021, 10:35 am
Baja Bilo.....
Yes that is my rig, should be able to pick it up in a couple weeks.
Re: New member
Posted: February 2nd, 2022, 9:19 am
by markatherton
awesome...please post pictures when you get it.
