Page 2 of 2
Re: Bathroom exhaust fan
Posted: September 14th, 2019, 5:02 pm
It looks like they have more than enough wire there, chin, although that's an interesting tip.
Steve's point is what matters. I would abide his first suggestion and use marine crimps. Although they usually work just fine, threaded wire nuts aren't the best choice in a mobile application with the vibrations we experience, even in a low voltage fixture. Ever worked on trailer wiring? :lol:
If you don't have the correct connectors or crimpers, solder and shrink tube is a fair backup approach.
Posted: September 27th, 2019, 4:30 am
by Jeliso
The bathroom exhaust fan https://thehomedweller.com/bathroom-exhaust-fan/ works okay but seems a bit small.
Since moisture is the most damaging thing to a RV, whenever we take a shower I like to rid the bathroom of as much moisture & as fast as possible. The fan that came with the Monty just seems too small for the job.
I am assuming the fan is 12 volt. Is there a bigger fan that would fill the entire opening & still be 12 volt? Is this a wise change to make? How do others handle this problem?
Thanks for any info guys.
Posted: September 27th, 2019, 5:31 pm
Just posted on this a few weeks ago:
viewtopic.php?f=7&t=1606&p=14818#p14818
There is a Heng replacement fan available that is bigger and lets you keep the top half, and a ring of LED lights that can replace the old ones.
