Page 2 of 2
Re: Camco portable big red campfire
Posted: June 11th, 2020, 5:57 pm
by Fjb
Update.......Here is the latest info received from Camco.........
The Big Red Campfire requires a fair amount of gas to get the fullest flame. You can hook it up to the 3 port tee (59103) directly but you will need the one pound bottle adapter to go between the 3 port tee and the Campfire regulator. If you use the hose that came with the 3 port tee then the one pound bottle adapter (59213) will go between the campfire regulator and the extension hose. Using the 3 port tee as the supply for the campfire may reduce the flame output. The campfire was designed to be connected directly to a propane cylinder.
Posted: June 11th, 2020, 9:02 pm
by Fjb
This illustrates how to hook up a Camco Big Red Campfire to a 1 lb tank......
Posted: June 29th, 2020, 5:33 pm
by Fjb
We purchased both Camco products and it works great! Nice flame and heat 😎
Posted: June 29th, 2020, 7:14 pm
I could go out and measure if it is close, but having just been working in the generator compartment I can say that on mine the floor space dimensions are about 19-1/2" x 34", and the door is about 13-1/2" tall and 28" wide (less sure on that last point but close). The compartment itself is around 15-16" tall once you are inside the door. It's huge! I feel like I gained another room (when I took the generator out).
Posted: August 29th, 2021, 6:13 pm
by Fjb
Update…….the Camco Big Red Campfire fits nicely in our storage area that also has the batteries on the left side with a divider so that we have the fire pit plus sewer and water misc in a bin on the right side.
