If you are interested in using epoxy, WEST System (sort of the grandparent of marine epoxy) has a free guide that explains everything in good detail with illustrations. It is free to look at or download on their website. And the principles apply to any similar brand. I like either WEST, MAAS, System Three or similar. MAAS and System Three are a little easier to mix by cup, as they are 3:1 mixes (WEST is 5:1), but WEST is available more neighborhood places and their phone support is top notch. But any similar good marine epoxy (not "hardware store" epoxy) will do an excellent job.
Yes, the Concourse it built differently. There is no "stick framing" to speak of. Plywood is used instead. If you are interested, you can look up the wall and roof "innards" details in the Reference sub-forum - I posted them there. They show a '99 Concourse (conveniently for me). I have been deep into the walls in my rig (as in I basically gutted parts of it), and everything has matched up to those drawings nearly exactly. But I already had the idea the Premier (at least in the 90's) was a bit different as another member and I were discussing a repair and he showed how his Premier was "stick built" around the windows, not plywood.
On the refrigerator. I don't think I would have been able to take my original one out the door (not that I tried). But it was the slightly larger one that comes in the Concourse. And also the Concourse has a Corian countertop "ell" just across that inhibits it coming out of its hole.
Since I knew I wasn't putting it back in, and since my new refrigerator would *just* come in through the door, what I did was cut my old refrigerator in half (easy, ten minute job) and then took each half out the door (fit easily then!). I had heard that Chinook brought them in through the window hole (sans window), but I wasn't going to remove a window just to get rid of a refrigerator I was not keeping. So, break out the Sawzall!
My new refrigerator just slipped in the doorway with the door removed. Let me look up how deep it is....okay, the body is about 20-1/2". Reason I say about is that it's actually 21-7/8" but there is a 1-3/16" tube on the back in only one spot that makes up the difference. So you can kind of rock around that in the doorway.
Other people have said they took it out the passenger door by removing the seat, but the one thing that mystifies me on that is that the Ford doors don't really open that wide -- so I have trouble envisioning how it gets through the Ford doorway; but maybe it does that just fine. Certainly easy enough to remove the passenger seat in my era (takes about ten minutes max - just four fasteners and an airbag clip ('97 and up have passenger airbag).
